spart666
hi all
someone tell what ive done and how to sort
had a few probs with the wiring of the busa getting a manual sorted most of it
putting on new motogadget clocks and idiot light cluster
everything works high beam, oil fuel pump arms, side stsnd switch works
all lights indicators work starter works
when i was wiring up the nuetral light it was on. i accidently :nocomment:
touched the orange and green wire to the blue and black positive/neg of the nuetral light led and off it went
so checked fuses all ok
run another wire to check if the led in the cluster had blown its fine
the problem seems to be with the feed to the nuetral light
the blue and black wire, the orange and green wire is also used to power the oil light thats fine
put an led on the neutral wire its on but you can hardly see it same led on the other points ie indicators high beam oil light its really bright
so what do i check and do :shakeno:
