05calibusa
I found a lot of threads related to this issue and it makes me wonder if changing the geometry of the setup has something to do with fork "wobble". This weekend I installed lowering links and dropped the rear using the middle hole on the dog bones. I already had handlebar risers on the bike, so I loosened the triple clamps and dropped the clamps down approx 3/4" on the forks. I also took some of the pre-load out of the rear spring. I took the bike out for a test run after getting everything tightened back up and noticed that I have fork wobble on deceleration. It is not bad, but I can tell when I let go of the bars. I did not have this problem before changing the setup. Any suggestions?
