Results 1 to 15 of 15
  1. #1
    Rookie 1BadAssBusa's Avatar
    Join Date
    Dec 2006
    Location
    Severn, MD
    Posts
    138
    Default 2nd Gear Hesitation
    Looking 4 some help.... When I'm in 2nd gear, and crack the throttle, the bike hesitates around 7000-8000 RPM. This only happens in 2nd gear. Any thoughts on what might be the problem?
    06LE Busa - Full Muzzy exhaust, PCIII, K&N filter, Galfer SS Brake Lines, Tobin Seats, PM Wheels, Pit Bull Spiked Collar, Illumiglo gauges, 42 th rear sprocket, Speedo-healer, custom front fender & rear hump. . . And in case you didn't notice, CHROME!
  2. #2
    jch364's Avatar
    Join Date
    Mar 2006
    Location
    Dayton Ohio..yes it sucks here
    Posts
    1,689
    Default Re: 2nd Gear Hesitation
    gear could be slipping. mine did this. kinda felt like a little jerk. only when i got on it. if taking it easy then nothing. pretty common if you drag race or are real hard on the gearing. i posted a thread on my rebuild about this very thing
    06 busa red/black,alien head,ecu editor
    1397 kit
    air shifter,shift light
  3. #3
    Hayabusa Immortal
    Professor's Avatar
    Join Date
    Nov 2004
    Location
    Oklahoma City
    Posts
    8,843
    Are you sure it is a hesitation and not a slip?
    03 AE
  4. #4
    Top Gun
    071300r's Avatar
    Join Date
    Jul 2007
    Location
    Florida
    Posts
    1,393
    my 2007 did that sounds like undercutting time
  5. #5
    Call me Liberace!
    ogre's Avatar
    Join Date
    May 2009
    Location
    The Northwest
    Posts
    5,142
    my 06 does that, only under WOT acceleration. soon as i get a chance i'm getting the trans undercut.
    Thankful for his Friends...
    2006 Raiment White Hayabusa
    Lumen Junkie in Residence
    Why retros are safer than HID kits
  6. #6
    Join Date
    Dec 2006
    Location
    Severn, MD
    Posts
    138
    I guess it can be called a slip as well. It only happens under hard acceleration, and only in 2nd gear. What does undercutting the trans mean?
  7. #7
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    11,780
    How many miles are on the bike?
    Do you power shift, or do you use the clutch all the time?
    Also gen one or two?
    04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit!
    92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP
    99 BUSA, SOON TO SEE THE ROAD AGAIN
  8. #8
    Join Date
    Dec 2006
    Location
    Severn, MD
    Posts
    138
    10K miles on the bike. Gen 1, and I always use the clutch to shift
  9. #9
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    11,780
    Quote Originally Posted by 1BadAssBusa View Post
    Sound to me like the motor need to come out! Sorry to say, but the busa's have had the same problem for all the years.
    Second gears are notorious for going bad!
    As for the fix, it has already been said to undercut the transmission.
    What undercutting achieves, is the gears will engage more than they do stock! In simple terms.
  10. #10
    Join Date
    Dec 2006
    Location
    Severn, MD
    Posts
    138
    Thanks 4 the info. Any idea how much $$ this will set me back? I might consider this work now that the riding season is over (cold weather)
  11. #11
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    11,780
    Are you able to remove the motor?
  12. #12
    Call me Liberace!
    ogre's Avatar
    Join Date
    May 2009
    Location
    The Northwest
    Posts
    5,142
    if you can pull the motor, ape will do it for 328. that's every gear. i would also assume there's some sort of shipping charge also.
  13. #13
    Join Date
    Dec 2006
    Location
    Severn, MD
    Posts
    138
    I do most of the work on my bike, but I do not have the tools or confidence to remove the engine. Guess I better prepare to get ripped by the dealer or speed shop.
  14. #14
    Join Date
    Nov 2010
    Location
    Birmingham AL Area
    Posts
    Just got word from my dealer, who I have trusted with my '06LE through 49,400 miles, that the transmission has been causing my skips at 5200 RPM and then again at 7200 RPM in 2nd gear. He is quoting $2500 to $3000 to pull the tranny and have it worked on. Is this realistic? We started looking at the K&N air filter, then the Smart Ivan TRE, then the front and rear sprockets and chain, then the fuel pump which was throwing only 27 PSI at high RPMs.
  15. #15
    Top Gun sixpack577's Avatar
    Join Date
    Jun 2009
    Location
    VA
    Posts
    6,669
    Quote Originally Posted by NewBamaBusa View Post
    Considering that having the trans gears themselves machined(undercut)is $400 to $500, I'de say they're rippin you one.
    Christ is Lord
Similar Threads
  1. 2nd gear issue only no other gear
    By FILT166 in forum Busa problems
    Last Post: 08-13-2009, 02:52 PM
  2. 2nd gear
    By busa108 in forum Busa problems
    Last Post: 10-01-2007, 05:28 PM
  3. 2nd gear hesitation
    By knockoutms in forum Busa problems
    Last Post: 07-17-2007, 08:02 PM
  4. 2nd gear issues and only in 2nd gear it does it.
    By FILT166 in forum General Bike Related Topics
    Last Post: 08-21-2006, 08:30 AM
  5. 2ND GEAR
    By major in forum General Bike Related Topics
    Last Post: 04-27-2004, 01:51 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
