annoying noise
irishbusadude
hey all,ive got a 1999 busa,it is making a noise at the dash headlight area as i go over uneven bumps or roads,i thought it was brake pads rattling in calipers so i removed them drove it op bumpy street and noise still there,checked steering damper thats fine,it seems as thou inside the headlight sumthings loose,any1 have same problems or remedies,thanx :thumbsup:
Is it a buzz? It might be the windscreen... remove it and put some electrical tape around the ears where you put the fastener through, and also around the front tab that goes into the fairing...
no mustang windscreen is ok,no pwall all screws and fasteners tested and tightened,it seems to be coming from the headlight unit,thanx for thoughts thou :thumbsup:
