Check sign and high temp???
JShayabusa2006
Hey everyone
I'm a little worried.. So I bought a 06 busa with 7500 kms and I dunno but before I turn my beauty over the check sign comes on display and oil light and as well the bike temperature goes straight up to HOT! But the bike isn't even hot??? What does this mean???
Thanks folks anything helps
Everyones' does it! When the ignition is turned on, the bike electronics do a boot up, similar to your computer. If you notice, your rpm's should do a full sweep from 0 to redline when you turn the ignition on. This is completely normal. The check engine light and oil light will turn on for a split second also. However, when the bike is running and you see these codes you SHOULD be worried.
Hope this helps
Yep, completely normal to let you know the gauges and lights are all working.
