i will make this as short as possible, i have a 2000 hayabusa with 13lbs of boost. the bike ran great until 1 day i went out and she started loosing boost , shortly there after the bike would not rpm over 6200 and hasn't for the last 2 freakin months. i've tried figuring this out with several people as there is no shop within a 1000 kms of me. the bike idles great, starts great , i've changed the fuel pump and rectifyer, the injectors are new , the diaphram and shim in the fmu are both fine and the fmu will increase fuel pressure fine also. the ignition coils and plugs are fine, the stator has great power, no fuses are blown, the computer is showing no codes, no burnt or broken wires found, i even ran the bike in the dark to check for ground or spark issues and nothing. i even changed the kickstand switch!
its nothing mechanical , and everything sounds great until i start revving it up and at 3800rpm exactly every freakin time, she will drop fuel pressure from 40psi to about 20 psi and bounce from 20 to 30 psi quickly, at 6200rpm shes done and it sounds like a rev limiter sound when it hits that rpm. what in the f--k am i missing guys???lease:
