Vacuum routing need help asap.
1Falcon989
Need to know where the vacuum line goes that runs between the two left throttle bodies then into a tee. One side of the tee has a long line leading to the right side of the motor and the other side is a very short line which is what I'm having trouble with... Need help asap! Thanks.
Figured it out.... Now what attatches to this vacuum valve?
the sensor in your pic looks like the APS (atmospheric pressure sensor, aka-Static pressure) no hose gets connected to that one. The vacuum hose from the TB's should connect to the IAPS (intake air pressure sensor). It's located in a similar spot. If I recall correctly the APS sensor only has two lead wired while the IAPS has three wires.
