ericlondonhayabusa
I was riding on the freeway (with my girlfriend pillion) on my '06 Hayabusa when my motor suddenly cut. Luckily, I was able to move to the shoulder without incident.
I turned off the ignition, turned it back on and the motor started right up. Not knowing the issue, I drove off the freeway (I was next to the offramp) and left the bike in a parking lot for the afternoon. We later returned to the bike, it started right up and ran fine until we were nearly home, at which point the motor cut again when I was turning onto my home street. Again, turning the ignition off and back on worked and we made it home safely.
Since I had recently installed a TRE, I thought perhaps that was the issue so I yanked it and rode around the block, but my motor cut again.
This time I did more research and it became apparent that the issue might be the tip over sensor (which automatically cuts the engine if the bike falls over). Sure enough, the tip over sensor was hanging from two wires by my rear brake master cylinder - the bracket had somehow broken. I rigged a temporary solution and will have a buddy weld it back for me, but this is one of the most serious safety defects I have ever encountered on a bike. It appears from various postings here and on other forums that this might be an issue with several Suzuki years/models. I searched on the NHTSA website for any recalls related to the Hayabusa specifically but could find none, including none in progress.
The purpose of this post is three-fold:
1) to let people know about this serious safety issue (I would inspect for this on a regular basis) AND
2) to obtain feedback from other forum members as to whether they've experienced this issue, especially if it's created a dangerous situation SO THAT
3) I can file a safety complaint with the NHTSA. I would like to get as much feedback from others so I can include it in my complaint.
Thanks,
Eric
Thanks,
Eric
