Lucid
I've researched this for several hours now, and I have some ideas but I don't want to waste any money if I don't have to.
I got a 99 a few weeks ago.
I know it needs a battery; I think it has the original one. (the owner used a tender) I had to push start it yesterday for the ride I will mention later.
The bike has 24k on it, and when I got it, the tag was out of date by about two years. He said he only rode it a couple of times a year for the past couple of years.
Everything was running fine for the first 1k miles or so. (I ride a lot)
I changed the plugs to some iridium ones because I've liked them in other cars and bikes. I also might spray a small shot at the drag strip eventually.
After the iridium plugs, it seemed to not like starting as much, but this could be the battery getting weaker, or me not using the choke. (I forgot I even had one on a fuel injected bike, I haven't used a choke in years)
Problem: I was riding yesterday and about 5mins in on the highway at about a constant 75mph, I noticed a very minor exhaust bogging sound when accelerating up a hill. Not a huge deal I thought, it could need a dyno tune since I have a full exhaust, new plugs, etc.
The the FI light came on, and blinking FI on the clock. The manual says this means it's still ride-able, but that something's up. Then I felt one pretty big hesitation, literally pulling me back for a second. I kept riding, looking for an exit, and about a mile later it did the hesitation again, but a little worse this time.
Now I'm pretty worried, the last thing I want is serious motor damage.
I exited, let the bike idle for a minute or two (worried it wouldnt restart if I shut her down because of the weak battery and/or FI light) and rode back home on backroads going pretty slow. No problems on the way home.
I haven't ridden since, but I got C00 code, meaning no malfunction? From the way it felt, I was thinking it was fuel related. Filter, pump, etc. But I don't want to tear apart my tank until the winter to replace all that stuff if I don't have to.
I'm thinking about replacing the filter and fuel lines now, and an aftermarket fuel pump in the winter.
This can't be battery related right? Once it's started I should be good there
And the new, hotter plugs can't do this right?
What do you guys think?
