race24x
I did a search and really didnt find anyone that found the holy grail of answers for this. My bike like many others is surging very badly from 2-4k. I have pulled the screens froim the injectors, cleaned the screen in the beggining of the fuel pump, replaced the fuel filter, and spark plugs. I had the dealer set the valves and TPS as well as synch the throttle bodies. I tried unplugging my PCII. None of this helped. I am at the point where I believe it may be a bad coil or a leaking spark plug boot as it feels alot like a cylinder drops but only when you are trying to maintain a steady RPM in the 2-4k range. Accelerate and it is fine decel is fine. I do also occasionally get a little bump or skip or hesitation at idle if it idles for a long time. Just once in about 30 seconds like it loaded up and missed one fire. I am going to try dielectic grease in the boots and wrap some electrical tape around the outside of the boots. I am worried abotu a cracked coil or something like that. One other thing that really haunts me is that coold engine not all the way to full operating temp it runs perfectly. This only happens when fully warmed up. Do these Busas have an open and closed loop system? I was a GM tech for 7 years. I understand the basics of fuel injection.
