ok. the motor has about 7k on it and it just recently started to happen. the stealership told him he needed a new trans, and he couldnt afford to fix it, so i am trading him a tl1000r for it and im gonna tear into it. from searching i found that alot of times it is the shift forks that can cause this as well as needing to undercut 2nd. do you all think i should replace the forks and rods, or just have 2nd undercut?
