Jeep is right
there is a water drain ,in case you get caught in the rain ,up front on the bottom[ lower level of the airbox,,,the water will drain there,,there is no hose hooked to it,,its a ram air drain,,,theres another with a pinkish plug that needs to be cleaned,,thats the upper one in the back,,,,the water hose ,water shouldve rolledout the front drain,,Its a safe guard for the ramair,,the airbox is a 2 story level,,the ramairs are on the lower level with the front main drain,,,Air will flow thru the rams up into the upper floor thru the air filter then into the TB's,,,,,,ur ok,,,,,,,
