ok, so last winter I went to the closest Suzuki dealer around (an hour away) and said I needed new fuel lines. I wanted to fix the old hoses with new OEM parts. He checked the computer and showed me the 2 hoses, but they looked different than what I thought I needed. I said are you sure those are the fuel hoses between the tank and the pump, he said yes. I asked atleast 3more times because I thought they were the wrong parts, and he insisted that they were correct, so I ordered them. 10 days later, they came in, and when I finally got around to installing them, I realized he got me the small hoses for the drainage around the cap area.
Then I gave up and went to Autozone and got 2' of 5/16 ID FI hose for $4...works fine...that is what is in the pic. Actually a little long, only need about 10" for each run.
So make sure you're getting the hoses between the tank and pump, but parts store high pressure hoses will also work just fine.
