avalanche07
I have and 03 busa that will not start. After reading different post I have charged my battery overnight and still the same thing. After turning on the ignition switch I don't hear the fuel pump prime. I pulled the tank off again and this time I take the fump pump off. Pump looks fine. I have also noticed that the fuel gauge isn't reading correctly.
Check list(things I've done)
the clutch switch, the tip over sensor, checked fuses, charge battery w slow charger and tried to jump it w car battery( motor off)
Any other suggestions would help!
