no power when key is turned on
jcstarman1978
I have a 2006 ltd ed Busa with 800 miles on it. Parked it in the garage---it was running. A month later I took it out to start it and nothing! I know the battery is dead but it is sooo dead the charger won't even charge it. It indicates a bad battery. So I tried jumping it with my car and nothing happened. No lights no life at all. Yes I checked the kill switch and the battery connections are tight. Anything? .......John
if i recall, jumping your bike with a car was a bad idea but i don't recall why. obviously, grab a new battery since the current one is shot. lastly, i blew the ignition fuse accidentally on mine so maybe that is a possibility. the ignition fuse (30 AMP) is located next to the positive battery side, outside the batt. box. good luck and welcome to the org.:beerchug:
not 100% sure but read somewhere that a car battery has way too much juice for a bike. As already pointed out, replace the DEAD battery with a FRESH one. BTW, welcome!
You can jump a busa with a car as long as the motor is not running.
Also check your main fuse, on the gen 2 the main fuse box is on the left side of the battery.
Locked the bike with the ignition key? Switch setting put to parking light and didn't recognize it? Kills every bike battery after a month... and no charger in the world bring any current in it again...
Disconnect the minus terminal, then try the jumper cable again.
Connect "jumper +" on "battery +" and "jumper -" an footrest (or any other conductive piece).
Then try again... and post what shows up...
Ciao
D1
