Results 1 to 4 of 4
  1. #1
    dacrownedprince's Avatar
    Join Date
    Dec 2009
    Location
    Fayetteville, NC
    Posts
    39
    Default fuse blows when installing license plate lite
    ok so im trying to tap into my STOCK license plate wires with my new license plate lite--its just a simple bolt with the led lite in it--every time i splice the wires together the same 15amp fuse keeps blowing--i cant get the bike registered until i get this lite working--what am i doing wrong--
    "it's better to have and not need than need and not have"
  2. #2
    Hayabusa Legend
    jdsbusa's Avatar
    Join Date
    Dec 2008
    Location
    IL
    Posts
    2,030
    Default Re: fuse blows when installing license plate lite
    You're shorting it out or overloading that circuit - get a voltmeter/tester and make sure you've got the right wires and aren't crimping them together thus shorting them out. What kind of light is it you're installing?
    Put yourself on the ORG member map!!http://maps.google.com/maps/ms?hl=en...,0.084543&z=14
    '03 CBR954RR, '07 T-Busa - Sold, '03 R6 - Sold
  3. #3
    Join Date
    Dec 2009
    Location
    Fayetteville, NC
    Posts
    39
    just the basic bolt light--i think i found my problem but i wont know until i get home from work--i was using the brown wire as my hot wire because that appeared to be the original license plate wire--but i just saw a thread that listed the black/white tracer as my ground and the ehite/black tracer as my hot wire so ima try that--but heres a pic of the lites im using
    Attached Images Attached Images
  4. #4
    Join Date
    Dec 2009
    Location
    Fayetteville, NC
    Posts
    39
    ok got it figured out--jus switched the ground to a screw versus a ground wire
Similar Threads
  1. my new license plate
    By txbikerdude in forum General Bike Related Topics
    Last Post: 01-14-2009, 11:59 AM
  2. fuse blows when brake is aplied
    By redrocket in forum Busa problems
    Last Post: 03-27-2005, 09:43 PM
  3. What does you License Plate say?
    By OB_WRIST~ROCKET in forum General Discussion
    Last Post: 06-28-2000, 02:06 PM
  4. New license plate
    By OB_VegasDude in forum General Discussion
    Last Post: 09-22-1999, 03:24 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
