Results 1 to 11 of 11
Thread: stock bolt
  1. #1
    Join Date
    May 2009
    Posts
    23
    Default stock bolt
    Hi guys, so today I was trying to change my chain and sprockets, everything was going smooth until i started to remove the front one and the bolt that holds the nut got stock. I kept trying, now is striped. I used some WD40 and a bolt remover with a drill. It does not move an inch. I dont know what to do. Please any advice, I'm going crazy, I'm in Japan so there is no such thing as take it to someone. Thanks in advance
    LG
  2. #2
    pipeline trash
    Barts Watersports Adventure Champion Bunny Grab Champion Chicken Champion Fly Shoot Champion Funky Pong Champion Rainman Champion Goo Slasher Champion Gunman Champion Sack Smash Champion Skate Park Champion Tontie Champion m_ridgeway's Avatar
    Join Date
    Aug 2009
    Location
    henryetta, ok
    Posts
    4,937
    Default Re: stock bolt
    Pics would help.
    Posted via Mobile Device
  3. #3
    Suffers from PBSD
    Blanca Busa's Avatar
    Join Date
    Oct 2009
    Location
    South Florida
    Posts
    20,078
    +1 on pics. Hard to advise without being able to scratch ones head over a pic.
    Can you possibly get one size smaller socket hammered on it now that it screwed and use an impact wrench to get it off ?
  4. #4
    GIXERHP's Avatar
    Join Date
    Jan 2003
    Location
    NASHUA NH
    Posts
    11,780
    Are you talking about the counter shaft nut?
    As stated pics will make this go some where!
    04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit!
    92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP
    99 BUSA, SOON TO SEE THE ROAD AGAIN
  5. #5
    pipeline trash
    Join Date
    Aug 2009
    Location
    henryetta, ok
    Posts
    4,937
    I think he's talking about the allen bolt that holds the speed ring/sensor (whatever its called) nut on.
    Hard to tell frome description. For me anyway lol. Just a poser with a lowered bike.
  6. #6
    Top Gun sixpack577's Avatar
    Join Date
    Jun 2009
    Location
    VA
    Posts
    6,668
    If you can get a punch, or even a big flatblade screwdriver against the end of the bolt and give it a few hard hits with a hammer it may help to break it loose, stripped or not.
  7. #7
    Join Date
    May 2009
    Posts
    23
    Here you go guys, sorry it took so long.
    Attached Images Attached Images
  8. #8
    pipeline trash
    Join Date
    Aug 2009
    Location
    henryetta, ok
    Posts
    4,937
    Shouldve left chain on first.
    The easiest way to get the front assmbly off is to have someone hold the rear brake while chain is still hooked up with it in N.
    Anyways I would reccomend just putting the chain back on just to hold it for. Doesn't have to be pressed together just get it together somehow.
    Then there's a few methods of attack. I don't think there's enough shoulder to get the craftsman exractor tool on there. So you can take a hacksaw and cut a straight slot for a flat blade screwdriver. I've never had luck with that on something real tight but its worth a shot.
    Or take an allen key and weld or epoxy it in the bolt. Any way your gonna thrash that bolt. And need a new one. Shouldn't be too much.
    Just my two cents maybe someone will have some better ideas than me.
  9. #9
    Join Date
    May 2009
    Posts
    23
    Hey mattstang, thanks for the input, I end up heating it with a torch, the head snaped off but i took the rest with a drill bit. Sorry it took a min but I just got back from TDY yestarday, so when you posted your idea i was allready gone. Thanks anyways
    LG
  10. #10
    On a Steel Horse I ride.
    BusaWizard's Avatar
    Join Date
    Dec 2005
    Location
    Kansas City, Mo.
    Posts
    11,451
    If you're not living close to the edge, then you're taking up too much space.
    Fast is easy. Quick is hard.
  11. #11
    Seasoned Pilot ROCKSTEADY's Avatar
    Join Date
    Feb 2007
    Location
    MA
    Posts
    425
    glad you got the bolt out heat was my choice just remember lots of the bolts are fastened in with locktite or freeze in from elements a good shock with a copper hammer or punch goes a long way
Similar Threads
  1. bolt ons with stock computer
    By kyote1 in forum Busa Mods
    Last Post: 02-03-2012, 10:11 PM
  2. What HP you got? Gen II Stock & Bolt on's.
    By Dr151 in forum Gen II Busa Information
    Last Post: 07-28-2009, 06:06 PM
  3. STOCK SOUNDING BOLT ONS
    By rpm9001 in forum General Bike Related Topics
    Last Post: 04-15-2008, 06:06 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
