kingbusa
Hi guys,
I have a 08 busa that has been left in the garage for about a month. I cranked the baby after I got back form my vacation with the jumper cable. It started right up and idle fine. About 2 days later I tried to crank it, it didn't work so I had to use the jumper cable and still won't crank. All the lights are on. Then under the battery (I guess) I heard some kind of pumping noise? Is that normal?
Is it a blown fuse or starter problem?
Thanks for the help in advance.
