06 Engine into a 99 Busa
BusaCorona
Hello all,
I finally got an engine for my bike:cheerleader:
I got the engine out of an 06 limited
Now the question is....Is there anything that I need to take off of my old motor besides the wiring harness for the injectors in order to use my computer with the new engine?
Please help. Thanks
Would be better to use the 06 electronics. I think it's the ECU, stator and rectifier. Not 100% sure tough.
all true statments.....:thumbsup:
I know the other .org site (tunning/logging section) has info on what connectors to repin to use the updated electronics. The new motor has the updated stator hub so it will not work with your old ECU.
If you are not updating the electronics you need to use your old stater, and flywheel, and the pick up sensor from your old stater cover!
