Busa with no Key how to start?
ca1badptc
NO its not stolen.
We put the Busa motor in to a Jr,Comp Dragster and having problen getting it to turn over.
Has any on put a toggel swith for the ignition switch.
and a puch button starter switch?
and if so how did you wire it?
Thanks Ralph
download the manual available here, it has a fairly good wiring schematic..
I would bet you need to power up the ECU, Ignition and fuel systems, you will need to find the wire color codes etc.. ..
the starter button is a no brainer...
Update
got it to turn over dash lights up.
now the problem is the fuel pump does not turn on.
it seams to be the ECU is not compleating the ground circut for the pump relay.
pulled the ECU out hope to find a 99-07 busa to plug into to rule out a
ECU.
RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
I thought I read somewhere that you need a resistor in the ignition circuit or you may damage the ecu? When I get to a real computer, I'll do a search.
object>
I don't know that i'd like those exhaust temp's pumping out on my slicks tho! Other than that, cool stuff.
