Oil in the Charger!Is it normal?
nosmemos
I have a battery problem.3 months,3 battery:banghead:
Then i read service manual.
@5000 rpm 13.5 - 15 V normal charging output writes in manual but when i turn throttle of my busa,voltage decrease under 13 V.Then i tried to open charger,started to drop oil then i didn't open it.
Is it normal that oil in charger?
(Sorry for bad language)
Yes, that is perfectly normal. We know it as the stator.
Anyway, just put a pan or something to catch the oil. Not much will come out. If you can put your bike on a rear stand, even less will come out.
Also, be careful with your fingers...that magnet is strong and has been known to pinch fingers.
Go through the entire trouble shooting section. Could be several issues. Good luck with it.
Normal...could be a bad rectifier.
Posted via Mobile Device
i unpluged my rear indicators from rec.,can it be the fault?
If you have the service manual, you will be able to test the stator and the rectifier and figure which is causing you grief.
