busa blinker problem
killaessien
this morning when i went for a ride i noticed that my left blinker was blinking way faster than normal, probably about double the pace. the right one is fine. is the fuse for the blinker? any help would very much appreciated, thanks.
Sounds Like you have a blown bulb. When the bulb blows, it is not pulling the voltage it is suppose too and causes the light to blink fast. Just like installing leds. It's eithet the front or rear on the left side.
Check your fluid :beerchug:
:laugh:
One of your bulbs is burnt out...so there is not enough load on the circuit...makes the remaining bulbs on that side blink faster.
