Go Back   Hayabusa.oRg > Technical > Busa problems
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 10-26-2009, 01:04 PM
Seasoned Pilot
Group: Members
Default '04 Stumbling @ 6,000 RPM
I have an '04 with Brock street megaphone, Brock top end kit, small airbox mod and PAIR removal. I had it remapped and dyno'ed in September because the engine was missing. After remapping it ran fine for a few weeks but the problem cropped up again: wanking the throttle causes the engine to bog/stumble at high rpm's.
I changed the plugs but the problem remains. An interesting comment was made by the dyno tuner. He said my TPS setting was off, but he reset it. Can the TPS setting move by itself? I set it myself at C00 years ago and carefully tightened the Torx screw to prevent the setting from changing while tightening.
I've seen other posts on similar stumbling problems here that addressed replacing the 'rectifier', which sounds like one of those old construction job practical jokes "Newby, go get the latex rhomboid hypothecator so's we don't have to seal this here concrete." I also read that it could be cam timing, but why would the bike run fine for a while then start bogging down again?
Does anyone have a diagnostic plan that I can use to sequentially locate the source of this problem. I'll start by checking the TPS setting and re-installing the new map. Any other ideas?
  #2 (permalink)
Old 11-12-2009, 05:09 AM
suzuka1980's Avatar
Seasoned Pilot
Group: Members
Default Re: '04 Stumbling @ 6,000 RPM
injector problems
  #3 (permalink)
Old 11-18-2009, 01:58 PM
Seasoned Pilot
Group: Members
Quote:
Originally Posted by suzuka1980 View Post
injector problems
No, found out yesterday it's the fuel pump. I will be on my third, for an 04 with 46,000 miles on it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
'08 stumbling Kainedogg General Bike Related Topics 8 06-09-2009 08:03 PM
The $700,000,000,000 bailout is going to happen Charlesbusa Random Thoughts 50 09-26-2008 11:45 PM
BIKE STILL STUMBLING 330fatbusa Busa problems 6 04-19-2008 08:46 PM
Power loss at 6,000 rpm BusaFever General Bike Related Topics 5 11-02-2003 11:51 PM
can\'t rev passed 7,000 rpm OB_richie General Discussion 4 10-04-1999 02:22 PM
(c) 1999-2010 Hayabusa Owners Group
