![]() Hi there, ive had a on going issue with my 1999 Busa, 8k on the clock, after many atempts to make it run right, the garage has installed a new injection system which for the moment seems to have cured her. The original injectors had different date markings2x BAS A and 2x WA24, so i've had a set of 4 NEW injectors, and a new fuel rail,pump and throttle bodies fitted and all seems well, the fuel pump tested 15% down on power. just thought id let you all know, hope this helps someone. |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| lack of power | jaganderin | Busa problems | 3 | 09-12-2009 06:07 PM |
| Fouled plugs, no power | jrmsr | Busa problems | 6 | 01-29-2008 09:56 PM |
| OIL BURNING crop dusting busa | orangebusa?? | Busa problems | 4 | 09-05-2004 02:53 PM |
| 2001 Busa Burning oil | 1620jz | Busa problems | 10 | 01-31-2004 08:28 PM |
| What is the best spark plugs for 99 Busa? | OB_Mr Bear | General Discussion | 13 | 05-19-2000 11:00 AM |
