Go Back   Hayabusa.oRg > Technical > Busa problems
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 10-08-2009, 01:35 PM
Group: Members
Default 200/50/17 rear tyre
i am running a 200/50/17 avon viper sport on the rear, and have found that the drive chain is rubbin the tyre. has anyone else had this problem and how have you sorted it without putting a new tyre on, as i cant afford to replace it.
cheers
  #2 (permalink)
Old 10-08-2009, 04:00 PM
Group: Members
Default Re: 200/50/17 rear tyre
you have something cocked it will fit and may look real close but it wont rub or touch you better re install it
  #3 (permalink)
Old 10-08-2009, 04:21 PM
dragracer237's Avatar
New Recruit
Group: Members
I use to run that same tire. i had a slight rub on the chain guard. I switched to the Metzler M3 and the problem was solved. Much better traction in the turns too. I got a little better mileage out of the Avon but the harder compound didn't give me any confidence in the turns what so ever
  #4 (permalink)
Old 10-08-2009, 04:35 PM
BA BUSA's Avatar
MotoGP Wannabe
Anime BlackJack Champion
Group: Donating Member
Check your chain slack...if it is too loose, you can tighten it up a bit and that should solve the problem. Should be .8"-1.2" of play in the chain.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
200/50/17 rear tyre Power Ranger Maintenance and Do-It-Yourself 1 10-08-2009 03:59 PM
New Rear Tyre Delboybusa General Bike Related Topics 5 05-20-2004 02:37 PM
New rear Tyre BLACKSHADOW Busa problems 7 04-28-2004 07:55 AM
New Rear Tyre. BLACKSHADOW Maintenance and Do-It-Yourself 3 04-28-2004 02:50 AM
BT010 200 rear tyre General Discussion 14 05-18-2000 09:54 AM
(c) 1999-2010 Hayabusa Owners Group
