Go Back   Hayabusa.oRg > Technical > Busa problems
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 09-07-2009, 09:11 PM
SxLxAxVxExN's Avatar
Seasoned Pilot
Group: Members
Default From turbo to stock.. need help
So my turbo motor blew (carillo H beam rod went thru the case) so I put a stock motor in the bike and took the turbo off, now the issue I'm having is this:
I am still running the bosch inline pump and begi fmu due to the fact that I'm still lookin to buy a stock fuel pump. Fuel pressure has been set at 42 psi with a stock map stock injectors but she's running too rich and is cutting off under WOT.
So I lowered the fuel psi to about 32 or so and its still cutting off under WOT.
What is the stock fuel psi supposed to be at? I'm clearly doing something wrong. Oh and I am only running the map sensor, intake air sensor.
Any suggestions?
______________________________________
07 Busa
05 GSXR 1K
09 GSXR 1K
  #2 (permalink)
Old 09-08-2009, 08:07 AM
Commuta_Busa's Avatar
Hayabusa Immortal
Enemy Shooting Champion
Group: Members
Default Re: From turbo to stock.. need help
you don't want a regulator that compensates. Is your fuel pump wired into the OE fuel system harness? The ecu adjusts voltage to the pump.
2009 Super Streetbike's Top Speed Challenge Winner
Unlimited naturally aspirated class
  #3 (permalink)
Old 09-08-2009, 01:40 PM
Seasoned Pilot
Group: Members
yes fuel pump is wired to the oe harness, and the vacuum lines aren't hooked up on the fmu so its running steady 43lb fuel pressure.
07 Busa
05 GSXR 1K
09 GSXR 1K
  #4 (permalink)
Old 09-08-2009, 02:05 PM
dadofthree's Avatar
Seasoned Beef
Group: Donating Member
Just go back with the Turbo
  #5 (permalink)
Old 09-08-2009, 03:25 PM
Seasoned Pilot
Group: Members
haha no thanks, turbo stuff will be up for sale shortly.
anyone ever see a rod do this?
07 Busa
05 GSXR 1K
09 GSXR 1K
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Video of my 03 Stock Motor Turbo Busa Vtakt67 General Bike Related Topics 38 09-07-2008 12:32 PM
Video of my 03 Stock Motor Turbo Busa Vtakt67 1/4 Mile 7 09-06-2008 03:19 PM
Limits of Stock Engine With Turbo's? endlessperformance Gen II Busa Information 8 04-09-2008 10:59 PM
ghetto stage 1 turbo and stock injectors crashedbusa Turbo 11 12-18-2006 07:04 AM
Video of R1 beat by stock non turbo 911 Nemisis Twisties 16 09-27-2004 01:31 PM
(c) 1999-2010 Hayabusa Owners Group
