Go Back   Hayabusa.oRg > Technical > Busa problems
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 08-25-2009, 06:08 AM
Group: Members
Default 03 busa overcharging
anyone know what could be causing this to happen? i checked tha voltage and its reading 16v.
  #2 (permalink)
Old 08-25-2009, 07:07 AM
MC MUSTANG's Avatar
Peace Keeper
Curveball Champion Crazy Koala Champion Brighton Bounty Champion Flash Poker Champion Fling The Cow Champion Desert Battle Champion QB Challenge Champion Rocket Racer MX Champion Shuriken Challenge Champion
Group: Administrators
Default Re: 03 busa overcharging
Out of curiosity, why did you check the voltage? Are you having some other problem? Does there appear to be any damage to any of the wiring to/from the battery? If there is too much juice, could be an issue with the generator or the rectifier...
Sounds like there might be something else going on though.
MCM
______________________________________
GSXcite - Crew Chief; Omslaw - Test Pilot/electrical advisor; GSXtacy - mechanic; Semi - mechanic
Grandpa Busa - structures; Zuk Racer - mechanic
G Joker - Parts expediter; thepusherc.g. - paint/body and mechanical adjustments; Nitrous Junkie - Ergos; Captain and Boaz - athletic supporters
All I remember is: ground, sky, ground, sky, ground, sky, ground, sky, emergency room!
  #3 (permalink)
Old 08-25-2009, 08:57 AM
Group: Members
MCM
ive replaced the rectifier and kickstand switch, this is my second batteryin 6 months, so thats when i tested to see if it was puttin out tha correct voltage as noted
  #4 (permalink)
Old 08-25-2009, 09:26 AM
MC MUSTANG's Avatar
Peace Keeper
Well, the charging system is actually pretty simple... not many things it could be... 2nd battery? Why did you have to change them? What were the symptoms?
  #5 (permalink)
Old 08-25-2009, 10:47 AM
djsin's Avatar
Lily's Daddy
Group: Members
16 v not far from 14.4 some cheap voltage testers are off by that much
  #6 (permalink)
Old 08-25-2009, 11:06 AM
Group: Members
its the secend battery that ive purchased this year, seems to me cooking tha acid cpmpletely out of them,symptoms are its cutting off while im ridding, only for a few seconds, no throttle response,rpm tac drops to 0, lights still work, but oil light or fi light comes on, ive replaced the kickstand switch
  #7 (permalink)
Old 08-25-2009, 11:08 AM
Group: Members
Quote:
im thinking that also, my dad give me tha one i have, that may be why he did.
  #8 (permalink)
Old 08-25-2009, 02:44 PM
Johnnycheese's Avatar
Hayabusa Immortal
Group: Members
there should be no acid in the battery if they were serviced correctly
if your bike isn't fast, the Cheeseman didn't touch it
Johnnycheese Performance
Master map making
Master turbo and NA builder
512-767-4273
  #9 (permalink)
Old 08-26-2009, 12:48 AM
dadofthree's Avatar
Seasoned Beef
Group: Donating Member
Sounds like a rectifier / voltage regulator issue. You shouldn't be seeing anything above 14.4 VDC from memory. Pull the manual and double check. 16 VDC would be cooking your battery.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
03 busa overcharging ncstunna Busa problems 4 08-05-2009 12:07 AM
is this bike overcharging? FTMFW General Bike Related Topics 2 06-03-2009 02:10 AM
(c) 1999-2010 Hayabusa Owners Group
