Hey guys/gals, I custom fabricated and installed a 1" solid riser comparable to the Genmar riser a few months back. Once installed the windscreen rubbed the brake resevoir, just barely but after time, it's just enough to pizz me off. Anyway, I installed a DB screen today and it is hitting the resevoir even worse than the stock unit and still, only on the right side. I took a few steps back to get a better perspective on the situation and found that sure as schit the whole front/nose fairing is twisted or leaning a little to the right. The left side has tons of clearance with the screen. So basically, is it possible that the P.O. put the fairings on in such a way as to cause this type of thing? Or is that not even an option at which point we're talking about something bent (or worse broken) underneath?
Thanks in advance
Thanks in advance
