1. Does the the oil pan "crush" washer go flat side against the oil pan or flat side against the bolt?
2. Am I correct that the "fast idle" lever can only be slightly adjusted? It looks like no matter how much you adjust the cable...the mechanism will only "push" the idle up so far. Unless there is another way to adjust it?
thks folks!
thks folks!
