the exhaust valves are fully open at tdc on the exhaust stroke, so i don't see how they could possibly hit the pistons during any part of the stroke cycle. the intake cam would definitely be a problem. i did a leak down test with both cams out, and all the cylinders were the same with no air coming out the throttle bodies or muffler that i could hear. should b just fine.
i installed a new cam chain, and i think the manual adjuster was too tight. the motor ran fine for over an hour, and then just broke. wasn't even reving it.
so im in the market for an intake cam for the exhaust side, and adjustable sprockets. thanx,
