what's up riders!!!!
Had a problem with the bike giving me a F I light code 32,33,34,35 jumped the wires checked ( injector, wires harness for in jectors, checked for loose wire, and the ECU ( I think I did it right the ECU kinda had trouble confused a little) for consist, resis , and volt checked out OK. Change the wiring harness to injectors also, but it was suggested to me to disconnect the PCIII, and run the bike with out it or borrow someones ECU with the same year( Couldn't fine someone with same year so I unhooked it). The bike ran fine no code comes up! BUT when I TRY TO GET ON THE GAS THE BIKE WANTS TO STILL OR BUCK, LIKE IT NEED GAS, THE RMP DROP SO I WILL SHIFT in a lower gear which is like 3rd, and it smooths out. But long as I stay between 112mph - 120 mph if fine, if I go harder than that the bike wants to stall.
Can u help Me Please the summer is Here!!!!!!!!lease:lease:lease:
