Engine Knock when cold.
falcon03
03: When the bike is first started, the engine has a knock. If you pull in the clutch it almost goes away. When it gets hot the knock is faint. The bike runs great and still has all of its power. The clutch does not slip either.
These are noisy engines. When it's obviously loud then there is a problem. If it's faint, or fades when the engine warms. I wouldn't worry too much with it. At least that's what I was told ???
