Speedo Needle "Twitching"
Longstone
I'm a little embarrassed about this but I figured if it's going to get fixed I needed to ask.
After doing the EP-35 install a few weeks ago my speedometer needle "twitches". By that I mean for the first few minutes of the ride I'll be cruising along and the needle will 'tick' or 'jump' a little. It seems after warming up for 10-15 minutes it's fine, and I don't see it at all. It should be noted it doesn't do this for the tech, or any other gauge. Just the speedo.
I'm hoping it's just the connection to the master assembly, or maybe I didn't pull the rubber piece up over the connections all of the way in the back master assembly and maybe it's getting some interference. Honestly I'm not sure.
Anyone have any ideas?
Yes I have HIDs, installed them a few weeks prior to the EP-35.
I would suspect them more myself... My HID's cause this issue on mine.. Well close as I can tell anyway.. I have been told that changing the VSS will fix ti but I have not tried this..
