Benesesso
Discovered a clutch problem during a ride today. Went to pass a car (6th gear) and just cracked the throttle a hair (nowhere near any turbo boost), rpm jumped up a thousand before the clutch grabbed. Hmmm, never did that before. As the ride progressed, the problem got worse.
I didn't let the clutch slip a lot, but finally it wouldn't engage at all. The lever pull never changed. Parked it at a safe location and got a ride home. Took my truck back to pick it up, and gave it a short test ride. Clutch was normal again.
So, which end of the actuator hydraulics should I check first? The bike has an aftermarket slave cyl. anti-dirt gadget.
