Throttle assembly broken?
SAme thing happen to mine when they dropped it off???
The grip was over rotated with the tie down straps....
they put it through Warranty,,,, ooks like the part is about 88dollars from suzuki.
Ok, so I took it ( throttle assy. ) apart and found that there is a small 3/16" or so "button" where the inside of the run/kill switch housing is that is broken off. Any ideas anyone:please:
2007 Suzuki Motorcycle Parts for GSX1300R (HAYABUSA), OEM and Aftermarket at BikeBandit.com
Not sure if i would buy off of these guys.... but has the all mircofiche of most bikes
It is go info and gives you a ball park figures on prices.
The blowup drawings are good for disassembly. see what you are getting into.
happened to mine also. i turned it all the way down and snugged up the screws a little more. worked for me.
trekfuel; thank you for the heads up on the fiche, the little part would be inside the top clamshell piece of part labeled number 1.
