im not sure all the signs are there tight then loose chain.and the chain walks left to right hitting the frame.
no real move ment looking at the sprocket with the chain moving it.
I need to put a dial indicator on it?
My question is how much work compared to OIL COOLED 1100 trans?
If i remove the front sprocket will this be plain as day to see the bent area?
HELP?
HELP?
