yikes i wrote that wrong... the hose runs along the RIGHT side, past the rear brake resevoir. The housing is mounted to the subframe on the RIGHT side, mounted to the upper side subframe bar. As far as trunk or tail... I would have to say right sideinside the tail. Hope that helps.
