Who makes a good Battery relocator. I like the one Tiger Racing makes but you have to modify the headlight. Any suggestions would be helpfull. I need to move the battery to make room for fuel and timing controls. I would like to move to the front if possible.
the only way to move the battery to the front is by either not running the headlight assembly or you can hack into it and still retain the high beam. The other option would be if you were running a turbo you could mount it where the right intake tube would be.
You can either mount the battery somewhere in the tail or for drag racing only Gatlin has a bracket that allows you to mount the battery down by the dog bones.
