Condition:
Stretched stainless brake lines Galpher Fronts)
Mods:
3/4 Reaper style riser (possibly the tall risers without the Helibars as well)
Helibars
FIX:
lower front end by 3/4" (this may be more if you have the taller reaper style risers)
When initially installed I did not notice this problem.. However when I had the bike supported by the frame and the front suspension fully extended, it pulled the lines "straight" and loaded them.. This is potentially a disaster waiting to happen..
I do know that there are 2 of us so far that have discovered this issue. If you are running risers and stainless lines, I would get the forks fully extended and check that the lines are not being pulled on..
I thought I posted this already but i guess not...
Mods:
Helibars
FIX:
