Go Back   Hayabusa.oRg > Modifications > Busa Mods
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 04-23-2007, 07:03 PM
hayabusaPuertoRico's Avatar
Rookie
Group: Members
Default
HELLO
I NEED SOME HELP WITH THE SHIFTER LINKAGE NUT, I BEEN TRYING TO REMOVE THE LINKAGE NUT AND IT DOESN'T EVEN MOVE ANYBODY CAN HELP ME WITH THIS PLEASE.
______________________________________
  #2 (permalink)
Old 04-23-2007, 07:08 PM
MC MUSTANG's Avatar
Peace Keeper
Curveball Champion Brighton Bounty Champion Flash Poker Champion Fling The Cow Champion QB Challenge Champion Rocket Racer MX Champion Shuriken Challenge Champion
Group: Administrators
Default
Have you tried spraying it down with WD40 and letting it sit for a minute? Might be enought to break down some of the slime sticking it together...
GSXcite - Crew Chief; Omslaw - Test Pilot/electrical advisor; GSXtacy - mechanic; Semi - mechanic
Grandpa Busa - structures; Zuk Racer - mechanic
G Joker - Parts expediter; thepusherc.g. - paint/body and mechanical adjustments; Nitrous Junkie - Ergos; Captain and Boaz - athletic supporters
All I remember is: ground, sky, ground, sky, ground, sky, ground, sky, emergency room!
  #3 (permalink)
Old 04-23-2007, 07:10 PM
Rookie
Group: Members
Default
<div>
(MC MUSTANG @ Apr. 23 2007,17:08)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Have you tried spraying it down with WD40 and letting it sit for a minute? Might be enought to break down some of the slime sticking it together...</div>
NO I HAVENT, THATS A GOOD IDEA , IM GONNA TRY TO SEE IF IT WORK. THANK YOU
  #4 (permalink)
Old 04-23-2007, 07:12 PM
Too much time to kill and money to spend
Group: Donating Member
Default
Which nut? The one at the rod end connected to the shifter is reverse thread, The end at the shift lever that comes out of the transmission is standard thread!
Hope this helps!
30 psi of boost, is like a hot chic with a std, you want to hit it but your afraid of the consequences!
  #5 (permalink)
Old 04-23-2007, 07:19 PM
dadofthree's Avatar
Seasoned Beef
Default
Robert 44,000 plus post
  #6 (permalink)
Old 04-23-2007, 07:21 PM
Rookie
Group: Members
Default
<div>
(05BusaLe @ Apr. 23 2007,17:12)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Which nut? The one at the rod end connected to the shifter is reverse thread, The end at the shift lever that comes out of the transmission is standard thread!
Hope this helps!</div>
Man how come you know so much, you are great brother thanks
  #7 (permalink)
Old 04-23-2007, 07:25 PM
Default
<div>
(hayabusaPuertoRico @ Apr. 23 2007,20:21)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE"><div>
Man how come you know so much, you are great brother thanks *</div>
Shhh! The secret is that I just had mine apart installing the electric shifter.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2010 Hayabusa Owners Group
