A few questions.. So, the original fan is still controlled (off and on) via sensor, correct? Also, I'm assuming the manual control is for the new 2nd fan only.. Is this right? 3rd.. How is the 2nd fan wired for power? Great write up.. Thanks for sharing.. Â* ______________________________________ Myspace Profile 2005 Hayabusa (Silver and Black) Lowering links Full Akrapovic, PCIII, Pair valve mod 17/40 gearing (stock) 10.2 @ 136mph.. For now Â* 2005 Honda CBR 600RR (Track bike) |
Here's the way that i do this mod. Here the link to my post!Second Fan Theres a different way to do this, on the electrical side, the way that i have done several of them, along with my own bike is you wire the 2 fans together, the oem harness needs to be taped into. The factory wirering is able to handle the as long as you swap the fan fuse from a 10amp to a 15 amp! Ill post up the rest of my pics later this week! of the fan being installed! ______________________________________
04 LIMITED BUSA, 1397 kit, intake cam swap, 50hp wet NOS kit! 92 GSXR 1100/1216 THE BABY I JUST CANT GIVE UP 99 BUSA, SOON TO SEE THE ROAD AGAIN |
Can;t wait I am looking foward to doing this mod. i just ordered my muzzy fan for the original fan and some engine ice. You guys rule ______________________________________
JZ 2003 BUSA! Black ang Grey Mototeck Undertail Vortex Frame Sliders Puig Racing Screen Yosh Exhaust Fairing Screens PCIIIr Muzzy Fan |
Hey busacruise we need your update on your 2nd fan wiring with photo's, please ______________________________________
There are several different ways to do this. you can use a gixxer fan, busa fan, or an old srad fan. The busa fan will have to be turned upside down to mount. Thats why most people use the gixxer fans....since they mount on the right side anyway. You will have to modify the mounts with any one that you use. You can wire them together or wire the second fan to a manual switch. the fuse will have to be upped to a 15 or 20 amp if you wire them together. You can also install a second temp aensor in the outlet tube of the radiator and hook the second fan to that. This way actually works best because the fan will kick on earlier. You cna also use a temp sensor from a Honda. It makes your original fan kick on earlier.
Do you realy need the second fan? Mine only gets hot at stop and go traffic in the summer and then the fan kicks on and cools it fine I may just get a fan sensor that kicks on at 160 that way in traffic it will cool a little sooner.
Honestly with water wetter or engine ice is a second fan necessary? Are there 10 degree lower thermostats available?
2007 Black 'Busa- Not Stock and new to me. ![]() 2007 Black Kaw ZX6- Geared, Jetted, Piped, and more. 2001 Black Buell Lightning X-1- Sold. 1993 Honda VFR 750F Interceptor, (yellow and black custom painted) Geared, Jetted, Ported, Piped. (first street bike) R.I.P.!!!! (lucky to be alive). |
| Thread Tools | |
| Display Modes | |
