Go Back   Hayabusa.oRg > Modifications > Busa Mods
Reply
LinkBack Thread Tools Display Modes
  #21 (permalink)
Old 01-23-2007, 10:22 PM
heavybusa's Avatar
Just another guy
Group: Donating Member
Default
<div>
(BigGeorge @ Jan. 23 2007,22:15)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Thanks, Lear. I pasted the wrong image... this is what I'm looking to get:
Will this work for me using the setup I described without the worry of amp load?</div>
Thats what I have
______________________________________
Greg
"Obstacles are those frightful things you can see when you take your eyes off your goal." - Henry Ford
  #22 (permalink)
Old 01-23-2007, 10:29 PM
BigGeorge
Default
Been wanting to do the mod since it started getting cold... but I want to do it with the acessory plug. Hopefully this will motivate me
  #23 (permalink)
Old 01-23-2007, 10:39 PM
Default
<div>
It should work just fine. You can find all the stuff you need at Powerlet.com. Remember, whatever you do, you have to have a way to disconnect your socket which is mounted to your frame cover, from your battery when you take the cover off. (The two white connectors that you see in my pics. Dealsgap.com (go to their website) also sells powerlet products and you'll be able to see all the connectors there. Hope this helps... and amps won't be a problem with a battery tender.
  #24 (permalink)
Old 01-23-2007, 10:41 PM
Default
<div>
(heavybusa @ Jan. 23 2007,22:12)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">See the battery tender plug back there. * </div>
It's camo! I can't see it! Must be my 57 year old eyes!
  #25 (permalink)
Old 01-23-2007, 10:50 PM
heavybusa's Avatar
Just another guy
Default
To the left of the 3 mounting bolts inside the pork chop shape
Greg
  #26 (permalink)
Old 01-23-2007, 10:52 PM
Default
<div>
(heavybusa @ Jan. 23 2007,22:22)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE"><div>
Thats what I have</div>
Hey Heavy... the actual web site for the stuff you need is: http://www.sporttouringusa.com/ I just happened to run across it on dealsgap.com. Just go directly to sporttouring.com and they have every you can think of to hook this stuff up.
  #27 (permalink)
Old 01-23-2007, 10:54 PM
heavybusa's Avatar
Just another guy
Default
Go check it out george!!
Greg
  #28 (permalink)
Old 01-23-2007, 10:55 PM
Default
<div>
(heavybusa @ Jan. 23 2007,22:11)</div><div id="QUOTEHEAD">QUOTE</div><div id="QUOTE">Nice work
Mine looks like this.
</div>
Got it!
  #29 (permalink)
Old 01-23-2007, 11:08 PM
heavybusa's Avatar
Just another guy
Default
Its long enough to pull out and plug, then I tuck it away while I am riding.
Greg
  #30 (permalink)
Old 01-23-2007, 11:24 PM
frisbee's Avatar
GODSPEED RACING
Default
mine barely stick out far enough from my seat to worry about . But that looks good .
second place is just a name for the first loser
3-9" 600 arm, #36 dry NOS, 208HP @ 137FT LBs Â*,BMC Filter, Airbox Mod, Adjustable Rear Links, 1" Reapers Risers, Yellow ZG DB, HID Low beam, Icemann Yellow Hi beam, Speedhut gauges, Carbon Fiber Everywhere, pusher cover
  #31 (permalink)
Old 01-27-2007, 10:56 PM
georgiabusa_05's Avatar
Fun Times!
Default
nice job.
05 BLUE/SILVER BUSA
Yoshimura RS-3 exhaust
McCulloch HID low beam
Leather by Joe Rocket
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
(c) 1999-2009 Hayabusa Owners Group
