need help understanding accel pump
ajm
I'm looking to get a full system muzzy, pc usb 3. I already have tre, k&n air filter. I wonder if I can order the pc to come pre-programed to these or do I have to do it myself? Also I do not understand the accel pump. Is this an option or something the pc already has? How does it work and what does it do?
ajm
it would be according to where you bought the p.c. some places will load the map for you. but you can do it yourself from there web site. or ask around on here to find a map close to what you need. the accel pump is something alot will say does not help and they choose not to run it. what id does is when you accelerate quickly it richens the mix.
+1
The accel pump feature is included with the PCIII usb's software, but it has to be turned on. When you buy the PC, it will have instructions on how to set it up - its easy. The accel pump puts an extra shot of fuel when you crack the throttle and you can customize the settings. The PC web site explains how it operates.
