View Poll Results: Suspension settings, front/rear... - How did u set up your busa?
Voters
19. You may not vote on this poll
  • 1" down in front/ stock rear height
    3 15.79%
  • 1" down in front/ 1" up rear
    4 21.05%
  • 1.5" down front/ stock rear height
    2 10.53%
  • 1.5" down front/ 1" up rear
    1 5.26%
  • 1.75" down front/ stock rear height
    0 0%
  • 1.75" down front/ 1" up rear
    0 0%
  • 2" down front/ stock rear height
    0 0%
  • 2" down front/ 1" Down rear
    3 15.79%
  • 2" down front/ 2" Down rear
    2 10.53%
  • I dropped it into the weeds
    4 21.05%
Page 1 of 2 12 LastLast
Results 1 to 20 of 35
  1. #1
    Hayabusa Immortal
    Join Date
    Mar 2006
    Location
    MI
    Posts
    5,330
    Default
    I would like 2 get some feedback on this from guys who street ride ALOT-if you're a track junkie please disregard... I ride my bike on public urban roads and freeways, no tracks for me 'cept the dragstrip.
    I was thinkn about going with a 1.5" drop up front and 1" rear, but a good buddy said he's 1.75" down in front and 1" UP in the rear, and bike handles sooo much better...i dont spend alot of time in the "twisties", Im a straightliner, so if you have a set up on your bike that works great for 1/4 mi. sprints and still gets you to work without a lot of fuss, lemme know.
    T.I.A, folks
    Revolution Custom Paintjob
  2. #2
    Hayabusa Immortal
    Join Date
    Mar 2006
    Location
    MI
    Posts
    5,330
    Default
    hello? a lil' help, here
  3. #3
    Used to be a SoCal Busa
    Charlesbusa's Avatar
    Join Date
    Jun 2003
    Location
    Grand Prairie, TX
    Posts
    14,901
    Default
    Hey, you said no track junkies allowed! * Your rules
    <!--EDIT|Charlesbusa
    Reason for Edit: None given...|1156112808 -->
    Proud owner of the filthiest Busa on the board.
    If there's time to clean it, there's time to ride it!!
    Nicky Hayden MotoGP 2006 Champion!!
  4. #4
    Hayabusa Immortal
    Join Date
    Mar 2006
    Location
    MI
    Posts
    5,330
    Default
    ahh, c'mon-fine, if the track junkies are the only intelligent folk here with suspension input (where'd Jinks go) I'll take it. just wanna here what works and how.
  5. #5
    Join Date
    Jun 2003
    Location
    Grand Prairie, TX
    Posts
    14,901
    Default
    Generally;
    For trackdays/racing, you want the bike higher.
    For drag racing, you want the bike lower.
    Raising the rear or lowering the front(not good for ground clearance) generally;
    Makes turn-in quicker/less effort.
    That's about all I know... *
    I like my bike set-up for trackdays, so my set-up isn't what you're after. I raised the front with stiffer springs for my body weight to improve ground clearance, then raised the rear even more than the front(1" for the rear).
    Reason for Edit: None given...|1156120108 -->
  6. #6
    Hayabusa Immortal
    Join Date
    Mar 2006
    Location
    MI
    Posts
    5,330
    Default
    thanks for input...jeez, i guess only one member on here has ever changed his setup...everyone else just dont like me
  7. #7
    Professional Pilot CrashBomb's Avatar
    Join Date
    Apr 2006
    Location
    The middle of nowhere
    Posts
    688
    Default
    I likes my fully adjustable d-bones. I'm down about 1" in the front and usually ride on the street with somewhere between stock and +1" out back. Then when I want to go to the strip and get serious I can just crank 'em down as far as I want 'em and I'm ready to go in two minutes flat, don't even have to take the weight off the swingarm. Here's wishing I could find a decent set of them for my Duke, it would make my life so much easier.
    "It's always better to be shot out of a cannon than to be squeezed out of a tube. That's why God made fast motorcycles, bubba."
    "Evil will always triumph over good, because good is dumb."
  8. #8
    Formerly known as &quot;Zuki&quot;
    Join Date
    Jun 2005
    Location
    MN72Busa
    Posts
    3,147
    Default
    Quote Originally Posted by [b
    Quote[/b] (CrashBomb @ Aug. 21 2006,01)]I likes my fully adjustable d-bones. I'm down about 1" in the front and usually ride on the street with somewhere between stock and +1" out back. Then when I want to go to the strip and get serious I can just crank 'em down as far as I want 'em and I'm ready to go in two minutes flat, don't even have to take the weight off the swingarm. Here's wishing I could find a decent set of them for my Duke, it would make my life so much easier.
    so how did you drop the front 1" ? Im +1 in the rear right now, but don't want to spend tons of cash to lower the front, and I wont strap it.
  9. #9
    Join Date
    Apr 2006
    Location
    Posts
    688
    Default
    Quote[/b] (Valium @ Aug. 21 2006,02:58)]so how did you drop the front 1" ? Im +1 in the rear right now, but don't want to spend tons of cash to lower the front, and I wont strap it.
    I just had my bud who's a CNC wizard fab me up some lowering blocks (risers, bar risers, clamp inserts, spacers, whatever you want to call them) and get me some good longer bolts because he owed me for putting the cams in his Sportster last month, so mine didn't cost me anything. Got them on last week and they made a ton of difference. It's a lot more comfortable now. You could go with a top clamp that allows the forks to slide up through it but I think they usually end up being more expensive than the kits that come with the blocks and the longer bolts.
  10. #10
    Hayabusa Immortal
    Join Date
    Mar 2006
    Location
    MI
    Posts
    5,330
    Default
    question guys-how did you raise the rear? and where to get that parts? $$?
  11. #11
    Busa Ridin' Sailor (ret)
    Join Date
    Jun 2004
    Location
    Glenpool, OK
    Posts
    3,774
    Default
    BigDiesel -- Here is what I did and I don't do any drags and no track days. It is all on the street. I did Jinksters settings with the following exception. I only rasied the butt 2mm not 4mm.
    I also loosed the fork clamps and dropped the tree down on top of the forks (~3-5mm). I love it. I am a big guy too, not quite as big as you. I am 6'2" @ 250 or so.
    Don
    2004 Limited - Sold
    2005 Limited - Sold
  12. #12
    Join Date
    Jun 2005
    Location
    MN72Busa
    Posts
    3,147
    Default
    Don,
    How did you lower the front / Raising the fork tubes 3 to 5mm, and get around the top triple tree cover not being pushed up? Longer bolts, or is there enough room for 5mm worth of tube to be raised in the tree? I guess I need some back-woods education on this ....lol
  13. #13
    Join Date
    Jun 2005
    Location
    MN72Busa
    Posts
    3,147
    Default
    Quote[/b] (BigDiesel @ Aug. 21 2006,21:14)]question guys-how did you raise the rear? and where to get that parts? $$?
    +1 dogbones from Schnitzracing...about $40.00
  14. #14
    Professional Pilot
    Join Date
    Dec 2004
    Location
    Houston, Texas
    Posts
    646
    Default
    I thought you lower the bike front and rear for the dragstrip?
    I'm about to lower mine 1" front and rear with the capability of lowering it more with the adjustable links from soupy.
  15. #15
    Join Date
    Jun 2004
    Location
    Glenpool, OK
    Posts
    3,774
    Default
    Quote[/b] (Valium @ Aug. 21 2006,21:42)]Don,
    Valium,
    I was feeling alot of "wiggle" in the handle bars. I started looking and realized there was a gap between the triple tree and the top of the forks. When I had the nose off to do the HID install, I loosened the fork bolts and let it slide down 3-5mm until it stopped. Loctited and torqued the fork bolts and the bike IMMEDIATELY felt more solid in the nose. I went to the dealership to check the new bikes and all of them have that gap and the "wiggle". I decided the gap was for vibration isolation. It is much more solid now.
    The guys that use the lowering bushings lose that gap as well.
    Don
    2004 Limited - Sold
    2005 Limited - Sold
  16. #16
    Join Date
    Jun 2005
    Location
    MN72Busa
    Posts
    3,147
    Default
    Quote[/b] (usn04limited @ Aug. 21 2006,21:47)]
    Valium,
    Don
    3 to 5mm for vibration isolation Don, I trust what you say, but that sounds like alot of wiggle room. I know you said the new bikes were all this way....just sounds odd...are you sure that 3 to 5mm gap is not there for any other reason, and is it completely safe to take up the slop that the factory left in there? I want to do the mod, but don't need a tank slapper at 100 mph either...so Im just being extra cautious with this mod.
  17. #17
    Hayabusa Immortal
    Join Date
    Mar 2006
    Location
    MI
    Posts
    5,330
    Default
    any opinions on dropping bike front/rear 1" ? does this make handling suck ba11s, or can I still turn corners without fallin off?
  18. #18
    Join Date
    Jun 2004
    Location
    Glenpool, OK
    Posts
    3,774
    Default
    Quote[/b] (Valium @ Aug. 21 2006,21:52)]
    Valium,
    Don
    John,
    I am not sure that is the only reason for the gap.
    I had the same questions as you.
    I thoroughly inspected Shimbumi's bike after his pingel bushing install and the gap that is in stock bikes is totally gone. As a matter of fact the pingel instructions tell you to let the bike slide down on the forks until there is not gap left.
    I have had Guinevere thru rather aggressive riding (destroyed the last 1/8 inch of strips on both sides) and to the end of the speedo since lowering the nose that little bit. She is more solid and predictable that she was before.
    Don
    <!--EDIT|usn04limited
    Reason for Edit: None given...|1156215462 -->
    2004 Limited - Sold
    2005 Limited - Sold
  19. #19
    Join Date
    Jun 2005
    Location
    MN72Busa
    Posts
    3,147
    Default
    Quote[/b] (BigDiesel @ Aug. 21 2006,21:55)]any opinions on dropping bike front/rear 1" ? does this make handling suck ba11s, or can I still turn corners without fallin off?
    You will fall off, but you wont have far to fall, being that close to the ground...lmao...couldn't resist
  20. #20
    Hayabusa Immortal
    Join Date
    Mar 2006
    Location
    MI
    Posts
    5,330
    Default
    man, Im 6'7"...im NEVER that close to the ground...at least not all of me...takes a full minute for all of me to fall over n hit the ground from standing-er, stumbling straight-ish up
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
