Anyone that uses the direct wire powercord for the radar detectors can you tell me what wire you guys are using to tie the battery power for radar detectors? I just got my windscreen mount and wires from UPS...going to best buy for the escort 8500 now.
I hooked a power plug on my last bike on the sides of the dash fairings . I could plug in a cord that hads a lighter plug in on it but it was only good if I was useing my tank bag . Maybe I'll PM Rythmn too!
If you pull out the guage cluster, there is a loose connector with a brown and black wire, I believe, on the right side. That's an accessory power connector. Just tap the power for your radar detector there. It will shut off power with the key.
<!--EDIT|Sane_man
Reason for Edit: None given...|1123283566 -->
Yeah, I have that tied into my gear indicator. Will it be ok if I splice into it and connect the direct wire? I kinda figured I'd have to do this but didn't know if it was ok to tie into it since it's being used?
