wickedsprint
Is it worth it if you still have stock exhaust, this may sound silly, but I want to keep this thing real quiet, likely for now just doing a TRE and maybe a K&N and a PC if it needs it.
on a PC3 altitude has nothing to due with the MapThanks for the replies, looks like some form of a custom map since most are drawn for sea level.
I'm at 5500 feet up and the tre hurt the throttle response on my 04 LE bigtime...made the throttle wayy more abrupt...and gave it a stumble at cruising speed. I'm curious to know what it does for you. When I get down to sea level I may try it again.I figure my elevation should help me a bit right now since I am at 6100 feet above sea level. Just ordered the smart TRE from Ivans, hopefully it cures the abruptness after a closed throttle I notice after compression braking into a turn, then needing to feed some throttle in.
you need to understand what stuff does. the altitdue only effect why you have no power the A/F stays the same if you are at sealevel or 6K up that is why a PC3 is nice it doesn't change the ecu just the injector pulse. the TRE changes the ECUReally? My bike wouldn't run richer than most due to my altitude? Does the injection compensate pretty well for this?
Is that map okay for a stock 'Busa? If so, watch for a PM from me JCbuy the pc from johnny cheese and he'll load his custom "slip-on" map in it and it should gain you a bit... plus a great price on the pc.
