Air shifter mounting
C_Henry
Anyone used the mounting bracket from Schnitz that requires you to disconnect the kill switch on the kick stand ? What am I supposed to do with it? This is the only one you can use with the stk exhaust I think.
you dont need to use a special bracket unless you want to mount the shifter under the foot peg. You can mount the shifter vertically from the bolt on the side of the frame. I can fax you the diagram i have if you need it.
