Cam swap
nitrousdog
Any one have the info on the intake/exhaust cam swap, what lobe seperation do you install the cams at. And what is the estimated hp benifet
<!--EDIT|nitrousdog
Reason for Edit: None given...|1104796285 -->
JC's mearly stating the truth...he usually cuts right to the chase (I think he's a bad typist)
Yer gonna gain next to nothing out of that setup...you'll loose hp down low, and maybe gain 5 or so in mid......don't bother!!
Two intakes, adjustable cam sprockets, Have the Intake set at 105 and Exhaust set at 107. Let a pro do it, if you have never degreed cams you'll f**k the motor up.
have been checking aout the web cams and their only good for about 2 hp over the cam swap, does cheese have a better grind than the web cams?
