| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
if you want to loose out on some bottom end torwue than go all small. If you want to retain the bottom end than keep them the way they are. Go +2 on the rear sprocket and that'll help give you more of a low end kick.
______________________________________ 2009 Super Streetbike's Top Speed Challenge Winner Unlimited naturally aspirated class ![]() |
| Quote:
Already there. MODs in sig. ______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle Last edited by MikeSomething; 11-04-2009 at 08:45 AM. |
| Quote:
Quote:
![]() I will take the bad one then... you gotta go out and blow $200+ on some shiny billet ones so you can hide them in the airbox and feel like you are going faster.... :flame-on:
______________________________________ Last edited by Mr Bogus; 11-04-2009 at 08:44 AM. |
| Thanks man, great. From what I've heard, the "Shiny" ones are alil longer then the small "Not Shiny" stock ones. Again, people have said, the stockers are to long and to short. So the aftermarket Velocity stacks are a middleground to create both low and top end power. But no one on this forum who has tested them is saying Yay or Nay.
______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle |
There is a reason behind the OE setup of shorts and longs. The fuel and ignition maps are taylored for the OE setup.
| Quote:
BTW...How the hell do you ride that thing in Carteret w/ all those potholes? ______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle Last edited by MikeSomething; 11-04-2009 at 09:05 AM. |
then you go buy two more OEM short ones... moves the torque curve up a bit.. OR a $250 set of shiny ones... ![]() velocity stack just works by using the momentum and weight of the air to pack some pressure behind the intake valve at WOT.. (little or no benefit at anything less than WFO) As the air velocity picks up, the less stack is needed for the effect and this is where the fun starts.. you can actually hurt a motors performance with the wrong setup.. you can see the effect with a timing light on some motors as the air pulses come right back out the top of the stack with a bit of fuel mist in it.. We used to tune the stack length until that mist was right at the edge of the top of the stack.. IF I had a video camera operator, I could show you the effect with water.. take a 1" tube about 3' long and submerge in a tank of water (fish tank works nicely) cap the end of the tube with your hand and raise the tube until it is most of the way out of the water.. NOW... very quickly, remove your hand and put it back on allowing about half that water to go back in the tank.. When your hand covers the tube back up, you will see what looks like a spring action as the water bounces up and down in the tube a few times.. The Velocity stack does that same "air spring" thing but much faster and shorter.. you will see where at one point, you could get a negative pressure effect in the tube (not good for tuning) and a positive pressure on the other end of the cycle (what you are looking for) oh wait a second.... does anyone know what a timing light is today? ______________________________________ Last edited by Mr Bogus; 11-04-2009 at 09:36 AM. |
| Quote:
The cheap weekend MODs are running out! ______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle Last edited by MikeSomething; 11-04-2009 at 09:57 AM. |
There's sacrifice some where to get some benefits. If you go all shorts you can gain some (very small increase) on the top end. You'll loss more on the bottom end though. Your "area under the curve" will be lower. Yes you can adjust the fuel to the inside cyclinders through certain power commanders but it's only a fuel trim feature. You can't change any spark timming just for the inside cylinders. Yea lots of pot holes in Carter-ico and my drag seat isn't very forgiving either. Until I put street gears back on my bike I don't take it out often. 1st gear is good until 90+mph so I'm always stuck in first. ![]() Since you're in NJ, let me know if you want to borrow a set. This way you can see how it feels. I'm less than a mile from the NJTP so you can take a quick high speed blast (at your own risk). ![]() ![]() PM me if you're interested. I can check tonight if I still have a set. ______________________________________ 2009 Super Streetbike's Top Speed Challenge Winner Unlimited naturally aspirated class ![]() |
| Quote:
| Finished Performance Modifications I went the route of Factory Pro to see if their claimed performance measured up....NOT! With the rest of my mod's I used the (4) short OEM stacks and got 178 HP, with the Factory Pro billet stacks only 171 HP and at top end the power curve dropped off like the edge of a cliff. Sold the stacks for a song but learned a lesson...oh yeah and I only use 87 octane pump gas too! ______________________________________ You Don't Stop Riding Because You Get Old, You Get Old Because You Stop Riding |
| Quote:
______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle Last edited by MikeSomething; 11-04-2009 at 03:46 PM. |
Whatever you do, DO NOT spend $200+ on the billet stacks.... Put that money towards a nitrous kit if you want more power... ______________________________________ CLICK HERE--> *Got-Busa's LSR Project bike* ![]() "TEXAS MILE - 3/28/09: 204.468MPH" All thanks to Brock's Performance and Johnny Cheese Tuned! |
| Thanks, what I'm tryin to find out, is if it's worth going from stock 2 small, and 2 big stacks... to just 4 small stacks which I can purchase for cheap or just not touching it?
______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle Last edited by MikeSomething; 11-04-2009 at 03:47 PM. |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Gen II OEM parts guide/torque spec/wrench guide | ks-waterbug | Gen II Busa Information | 21 | 10-21-2009 12:02 PM |
| Velocity Stack upgrade? | NC-BusaMan08 | Gen II Busa Information | 4 | 06-22-2009 09:47 AM |
| velocity stack install | Suzuki_kid05 | Busa problems | 4 | 04-21-2008 05:22 PM |
| Velocity Stack Combinations | vmaxbaby | Engine and Performance mods | 15 | 09-30-2005 06:23 PM |
| Smoking like a stack | electriceye | Busa problems | 1 | 04-05-2003 01:35 PM |
