| Garage | .oRg Forums | Portal | Blogs | Arcade | Gallery | FAQ | Classifieds | Calendar | Chat | Mark Forums Read | Sponsors |
| | LinkBack | Thread Tools | Display Modes |
| Quote:
If so can you post that... ![]() Quote:
______________________________________ CLICK HERE--> *Got-Busa's LSR Project bike* ![]() "TEXAS MILE - 3/28/09: 204.468MPH" All thanks to Brock's Performance and Johnny Cheese Tuned! |
| Quote:
Quote:
From what they said, stock gixxer stacks = 4 OEM shorties anyways. ______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle Last edited by MikeSomething; 11-05-2009 at 10:33 AM. |
| Quote:
may as well get a set of flat slides.. (and wrap them with heat shield material) ______________________________________ Last edited by Mr Bogus; 11-05-2009 at 10:30 AM. |
| Quote:
______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle |
| Quote:
Robert
| Quote:
Removed the entire airbox
Robert
| Quote:
you can make more power on the dyno and go slower at the track.. been there done that... my best dyno motor was .3 slower at the track than one of my middle of the road motors... you need best "overall" power in a range you can use it.. you spend very little time at redline... ______________________________________ |
| Quote:
I agree but you have to do your tuning and measurement somehow and the best measuring device we have at present is a dyno. I think if you look at the torque and HP lines comparing the two different charts there is an overall gain in HP and torque in the mid range, just to be on the safe side when I had the tuning done I reduced the counter-shaft sprocket by 2 teeth. With the additional elimination of weight and rotating mass I have more than made up for any loss of torque. ______________________________________ You Don't Stop Riding Because You Get Old, You Get Old Because You Stop Riding |
| You're sayin you dropped two teeth in the front...? And the aftermarket wheels ($3k+) helped w/ weight and whatnot...? Just tryin to understand.
______________________________________ '06 Blue & Silver PC3, TRE, Sm Airbox MOD, Full Yosh TRS, AFAM 17/42 Sprockets, EK ZZZ Chain, PP CT2's, R6 Throttle Last edited by MikeSomething; 11-05-2009 at 04:08 PM. |
| Dropped the sprocket size to lower the gearing and cut nearly 21 lbs. off the wheels alone. Anyone can tell you that by eliminating rotating mass or unsprung weight will give the equivalent of increased hp in acceleration and will also improve braking. Check out the price on aluminum drive shafts, thought about replacing the OEM transaxel shafts & drive shaft on my car. And you know my poor pea brain trying to remember if it was one or two teeth, now I have to go out and count!
______________________________________ You Don't Stop Riding Because You Get Old, You Get Old Because You Stop Riding Last edited by dmrowe; 11-05-2009 at 10:48 PM. |
| Quote:
| Quote:
sure you can tune and measure all you want... the real test is on the track.. you can not drag race on a dyno.. dont care what anyone says, I have seen more than one absolute dyno killer motor get pasted by an "also ran" motor.. sure you can optimize your combo on the dyno, but when it comes to the track? I have never seen a motor or combination perform its best until it has been tweaked on the track.. not saying you can not get it close.. Then you can then go back on the dyno and see where your tuning moved the power curve.. Vehicle and engine acceleration just can not be measured accurately in a static environment.. let me put it to you like this.. IF and that is a big IF the dyno was such a panacea of performance tuning... dont you think you would see the heavy hitter drag race teams with them at the track? really... they could make 4 or 5 pulls, tune the motor for the air and head right for eliminations... They dont, because it doesnt work.. (and I for one am glad, it would take the fun out of racing) and before anyone says "it is cost prohibitive" ... take a stroll through the pits at an NHRA national event.. you have privateer guys with a $20,000-$250,000 race vehicle with $500,000 truck and trailer just to drag it around.. These guys are dead serious about winning, if it worked, they would have it so fast your head would spin...
______________________________________ Last edited by Mr Bogus; 11-06-2009 at 10:43 AM. |
I got a set of small stacks sitting on my self at home, 20 bucks for the pair. shipped I'll see if I got one of my charts for my last dyno runs, but with a full Ti-force sumo hi-mount, intake cam swap, large airbox mod, air block off, and the four short stacks, tuned though a PC-3 on pump 91, I think I got 176hp outta her with 101 Ftpds. ______________________________________
I am the Parts monkey.
| Quote:
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Gen II OEM parts guide/torque spec/wrench guide | ks-waterbug | Gen II Busa Information | 21 | 10-21-2009 12:02 PM |
| Velocity Stack upgrade? | NC-BusaMan08 | Gen II Busa Information | 4 | 06-22-2009 09:47 AM |
| velocity stack install | Suzuki_kid05 | Busa problems | 4 | 04-21-2008 05:22 PM |
| Velocity Stack Combinations | vmaxbaby | Engine and Performance mods | 15 | 09-30-2005 06:23 PM |
| Smoking like a stack | electriceye | Busa problems | 1 | 04-05-2003 01:35 PM |
